Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
09-01-2009, 05:50 PM | #1 | |
Remote Starter installation help
Ok so I'm going to attempt my first auto starter install on my 99 Chevy Prizm, the starter is a Valet 551R. Now the car does not and never has had an alarm or starter installed in it before. So far I have printed the wiring diagram from here and have been reading the manual. I would just like to make sure that I have the proper wires going to the proper places. The stuff in bold and parenthesis is what is found on the cars wiring
Valet Wiring Harnesses H1 Primary Harness: Black Ground Wire - (Ground to Chassis) White/Blue: (-) Activation Input - (Momentary switch) Light Green/Black: (-) Factory Disarm - (Blue/Red (-)-Factory Disarm) Yellow: (+) Ignition output to security system - (Not Used) White: (-) 200mA Light Flash Output - (Red/White(-) - Head Lamp ) Gray/Black: (-) Wait to start - (Not Used) Light Green: (-)200mA Door Lock OutPut (Blue/White(-)-Door Lock) Light Blue: (-)200mA Door Unlock OutPut (Blue/Yellow(-)-Door Unlock) Heavy Gauge Relay Satellite Wiring Red: (+)High Current 12V Input (White or Black/Red-Constant 12V+) Red: (+)High Current 12V Input (White or Black/Red-Constant 12V+) Pink: (+)Output To Ignition Circuit (Black/White-Ignition) Orange: (+)Output To Accessory Circuit (Black/Yellow-Accessory) Purple: (+)Output To Starter (Red-Starter) Pink/White: (+)Ouput To Second Ignition Circuit (Blue/Red-Ignition 2) Remote Start Harness H2: Blue: (-)200mA Status/Factory Security-Arm Output (Not Used) Blue/Black: (-)200mA Optional Third Ignition Ouput (Not Used) Gray: (-)Hood PinSwitch Shutdown Wire (Not Sure Need Help) Brown: (+) Brake Switch ShutDown Wire (Green/White-Brake Switch) Violet/White: Tachometer Input Wire (Black-Tach, not sure where location is) Black/White: (-)Neutral Safety Switch Input (Red-Neutral Safety Wire....Red has already been used for starter, need some help here) Here is a screen shot of the cars diagram: Ok so is what have correct, if I missed something or did it wrong please correct me. Also Now this is my first time installing a Remote starter, but not my first time working on car electronics. |
