01-02-2009, 05:34 PM | #1 | |
2002 crv 69000 kms
First crv I have own i have had it since 44000kms I was going to take it in for maintence and check up to a honda dealer. Any suggestions on what i should have checked or looked at it seems to be running fine. thanks
01-03-2009, 09:50 AM | #2 | |
Re: 2002 crv 69000 kms
Do you have the owners manual? If so check the maint section. I have a 98 CRV and the spark plugs are to be changed at 30KMiles. You should also change the coolant and have the valves adjusted. You should also get the rear differential fluid changed at some point if it is the all wheel drive version. Have them check the brakes too.
Jeff |
