10-06-2008, 08:11 PM | #1 | |
95 caravan runs bad when warm
I Have A95 Caravan That Runs Good When Cold. But When It Gets Warm It Misses And Dont Want To Take Off From A Stop. But Runs Fine At Highway Speeds. Any Help Would Be Great.thanks
10-06-2008, 08:52 PM | #2 | ||
Re: 95 caravan runs bad when warm
It could be a varaity of parts failing. I would check coils. Take a hair dryer and apply heat to the coils with the engine cold and see how it runs then, if engine misses cold then you may have pin pointed to the coils. Possibility of camshaft and crankshaft sensors also but start by checking coils. Hope this helps |
10-07-2008, 05:31 PM | #3 | ||
10-10-2008, 02:29 AM | #4 | |
AF -Advisor
If the coil is good consider a new upstream O2 sensor. It's a major component used by the computer (PCM) to calculate air/fuel mixture ratio and fuel injector pulse width. Both will effect acceleration and ignition. When it's cold the engine uses a set parameter to keep the engine running until the O2 sensors heat up. It's called "open loop". Once the sensor heats up the engine starts "closed loop" operation and uses O2 sensor data in it's calculations. You may see a mpg boost with a new sensor. They cost from $60 to $100.
There is a consensus forming in the industry that O2 sensors should become a scheduled change item. They recommend for a van your age every 80k miles. I'm not sure if I would go that far but, if you've got over 100K miles it may not be a bad idea, especially the upstream sensor.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
10-10-2008, 05:03 PM | #5 | |
Thanks For The Info . The Coil Was Not It Still Looking. Im Going To Change 02 Sensor Now . Ill Post Up If It Works.thanks
