09-08-2008, 08:52 AM | #1 | |
Banned
Both front turn signals not working...?
I just purchased an '03. Both front turn signal lights are out; the previous owner said they'd burned out a few weeks prior, and seemed to think they didn't both blow at the same time. At $3.50/pr at autozone, I didn't make a fuss. But after I replaced both bulbs (they were indeed blown), the flasher still ran fast, and only the rear turn signals were blinking; nothing out of the fronts. I checked the bulbs, and they're still good.
FYI, no DRL; Autozone tried to sell me the wrong bulbs until I clarified that. Any ideas on what's going on here? |
09-08-2008, 01:33 PM | #2 | |
AF - Advisor
Re: Both front turn signals not working...?
You may have bad contacts in the sockets.
You need a meter at this point or a tester light at minimum. check the wires for voltage on the BACKSIDE of the socket, use a small sharp probe tip to puncture the insulation. If you have no voltage there then trace it back, this will require a schematic. You may have bad contacts in the sockets.
"I cut the header twice, and it's STILL too short!" |
09-10-2008, 12:56 PM | #3 | |
Banned
I think you need to replace your flasher relays and check your fuses. Here's what I found for you. LINK Link removed by Moderator - spam
09-11-2008, 03:52 PM | #4 | ||
AF -Advisor
You need a DMM and a wiring diagram and start checking from the sockets on back. Also check the grounds.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata Last edited by '97ventureowner; 09-12-2008 at 09:14 AM. |
