Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 12-22-2006, 09:32 PM   #16
Rollin Smoke
Re: Please Help Inconsistant starting 2.5L
All the symptoms the car have now are the same before I changed anything. I've been checking the vacuum lines, they all seem ok, but some are getting some cracks in them. I found a diaghram on the raditor with some vacuum lines. Should I worry about any of the small hard plastic vacuum lines?
I took the map sensor to autozone and they said it was working properly, so i dunno....
This dang car is really pissing me off...
Whats the best method for testing the wiring?
Rollin Smoke is offline   Reply With Quote
Old 12-22-2006, 11:13 PM   #17
xeroinfinity
out saving the world
xeroinfinity's Avatar
Even small vacum leaks can make problems.
Some are the tiny hard plastic ones up around the engine, they are more important usually.
The lines next to the radiator, if connected to a round black canister, that would be part of the evaporative emissions system. This burns gasoline vapors, much like the EGR reburns exhaust gases.
To test wiring is not easy to do.
You would need a good manual with the wire diagrams w/colors charted, and a good multimeter.
And I would say start with the ignition system,
like the ignition module the coils.
I never trust the guys at autozone stores.
Most dont know a crows foot from a crescent wrench
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
Old 12-23-2006, 07:24 AM   #18
Scrapper
AF Premium User
Angry Re: Please Help Inconsistant starting 2.5L
have you went to autozone or advanced autos store or any auto store to get you a hanes book for just your car??????? there prety good for the problems your having....
SCRAPPER.......
Scrapper is offline   Reply With Quote
Old 01-02-2007, 08:28 PM   #19
Rollin Smoke
Update:
Finally had an inline spark tester( ya know one of those lights that goes between the plug and the wire) to check for spark. It had no spark when I checked it. Took the tester out and then the car fired right up.
Could it/most likely be the distributor/coil? Hopefully I can tear it apart this weekend
Old 01-09-2007, 07:56 PM   #20
Rollin Smoke
Crank Case sensor was the root of all evil in my car!
Problem fixed, she starts like a champ, every time
Old 01-09-2007, 08:08 PM   #21
xeroinfinity
You mean the crankshaft position sensor?
Old 01-15-2007, 10:01 PM   #22
Rollin Smoke
Yeah thats it!!!
