Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
12-07-2006, 04:42 PM | #1 | |
ToeKnee
Help changing a capacitor!
I need to change a capacitor in a fosgate amp. The problem is that it has a bunch of numbers like 22000uf, 35v, and 105 degrees celcius. I bought one with 2200uf, 35v, but the degrees celsius are higher, does that make a difference?
12-08-2006, 06:53 AM | #2 | |
Audio Guy
Re: Help changing a capacitor!
I hope that one of uf is a typo ..... if the voltage is the same, the 22000 will be a LOT larger than a 2200. The 22000uf is the capacitance, the 35V is the maximum voltage rating, the 105 C is the max temp range ... as long as it is at least as high as the one it came with, you will be fine.
12-08-2006, 12:11 PM | #3 | ||
ToeKnee
12-08-2006, 01:45 PM | #4 | |
it just means the higher one can handle more heat. you are fine if it is the same uf with equal or higher voltage and temp ratings.
2001 Ford ZX-2 Alpine CDA-9855 SAX 100.4 Rainbow CMX 265 front stage Stock 5X7 rear fill Hifonics BX1505D TC-5200 |
12-08-2006, 03:16 PM | #5 | |
ToeKnee
yeah...that's what I tought, but I wasn't sure, thanx for the help guys!!!!!
