Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 10-26-2006, 08:53 PM   #16
desimunda
Re: Windstar 2002: Can't get caliper over new brake pads....
Originally Posted by garync1
I have a caliper tool as well. most cases on the single piston C clamps work fine. Another trick with a C clamp with multi pistons calipers is a strip of metal or wood thats thin enough but yet strong enough to back in the multi piston set up.
yes what i did was just used the old pad and the C clamp.
and i just did the pads 'fordboss' i didn't take the rotor off because they were in pretty good shape and the old pads still had some meat left on them. so i just assumed my rotor should be alright(no visible deep marks)...hopefully brake cleaner cleaned it good!
desimunda is offline   Reply With Quote
Old 10-26-2006, 08:53 PM   #17
12Ounce
On rear drum setups:
After removing the drum, use a digital camera to take several images at all angles before removing anything else. You will find this very helpful when reassembling.
BTW, I just yesterday replaced the front pads and front rotors on my '99 Winnie. Got about 150k - 160k miles out of these last aftermarket rotors. The mileage you get out of rotors varies so much due to different road conditions and driving practices. I do very little driving on unpaved roads, but I do occasionally tow.
12Ounce is offline   Reply With Quote
Old 10-26-2006, 08:54 PM   #18
desimunda
good tip thanks....i am going to go through both the fords manual and haynes.
Old 10-26-2006, 11:57 PM   #19
Ed_Strong
Son of a Mechanic
Ed_Strong's Avatar
Yes... the old inner brake pad is just perfect to get this acomplished, just leave it in place as you work the c-clamp or channelock pliers to get the caliper piston(s) resetted. Then remove the old pad and replace it with the new pad. That's the way i did it before I got the caliper tool!
Ed_Strong is offline   Reply With Quote
