09-18-2006, 11:59 AM | #1 | |
help removing intake manifold!!!
I'm replacing the head gasket on my 22RE engine. I have removed all the 8 intake manifold bolts, removed 2 pipes, and all the other bolts I can find. But, the manifold will still not come off. Is there any other tricks, or hidden attachments, I might be missing?
09-18-2006, 12:18 PM | #2 | |
Resident Chemist
Re: help removing intake manifold!!!
According to the manual, you install the intake manifold with the delivery pipe, injectors, and No. 1 air pipe with seven bolts, one hexagonal bolt, and two nuts.
Does this help? See the 1993 pick-up manual at the top of this forum in the sticky post.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
09-18-2006, 12:50 PM | #3 | |
thanks Brian. To remove the intake manifold, do I need to unattach or remove the individual fuel injectors from the manifold then? I was not able to figure out how to do that. Also, where do I see the manual in the sticky post? I can't find it. thanks
09-18-2006, 01:49 PM | #4 | |
Resident Chemist
The manual says that you don't have to remove the injectors. This is normal.
Here is the link from the "Combined Toyota Factory Truck Maintenance Manuals" thread: http://personal.utulsa.edu/~nathan-buchanan/93fsm/
