Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 05-22-2006, 11:58 AM   #1
moonmaiden
Question 95 E250 brake pedal goes to the floor - 4wabs
Having trouble with a 95 E250 brake pedal going to the floor when the vehicle is started.
Already replaced the master cylinder and booster. Master cylinder was bled and so was each line in the brakes. It is not leaking out of the lines or anything.
Does anyone have any other ideas? I would greatly appreciate it.
moonmaiden is offline   Reply With Quote
Old 05-26-2006, 01:00 AM   #2
gbic1
Re: 95 E250 brake pedal goes to the floor - 4wabs
Is this a diesel? If not then check your back brakse for adjustment and make sure your caliper pins are not seized on the front. Also make sure your front wheel bearing are adjusted correctly.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
gbic1 is offline   Reply With Quote
