Go Back   Automotive Forums .com Car Chat > Mazda > RX-7
Old 04-09-2006, 08:28 PM   #1
nodonniethisrx7
clutch problem
hi, so my clutch has been acting up for a while being really mushy. First I replaced the master cylinder and that didnt do anything so i replaced the slave and now its still doing the same thing. theres about 2 inches of play in the pedal before you can feel any pressure. Is this the springs?
nodonniethisrx7 is offline   Reply With Quote
Old 04-09-2006, 08:39 PM   #2
fb33112arx7
Re: clutch problem
Have you tried adjusting the play of the actuator rod that runs through the firewall into the master cylinder? I assume that you have already bled the system.
fb33112arx7 is offline   Reply With Quote
Old 04-10-2006, 02:07 AM   #3
FDTT
Re: clutch problem
Bad lines, in-proper bleeding, pedal freeplay adjustment
Dont drive faster than your angels can fly
FDTT is offline   Reply With Quote
Old 04-12-2006, 02:13 AM   #4
badassfocus1101
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
Re: clutch problem
sounds to me like u need to just simply bleed the lines properly
badassfocus1101 is offline   Reply With Quote
