Go Back   Automotive Forums .com Car Chat > Ford > Bronco
Old 01-28-2006, 10:14 PM   #1
JRRNTolkien
85 Bronco won't start, please help!
I've replaced the coil, plugs, plug wires, tfi module, and distributor cap. It's still not firing, though it sometimes fires once after letting go the ignition switch. I'm at my wit's wnd, can anyone help?
Thanks.
JRRNTolkien is offline   Reply With Quote
Old 01-30-2006, 10:30 PM   #2
JRRNTolkien
Re: 85 Bronco 2 won't start, please help!
No one has any advice?
Old 01-31-2006, 09:52 AM   #3
Truck
Re: 85 Bronco won't start, please help!
Did you check the ig switch? It's a bear because it's buried in the steering column, but those often go bad after a decade, or two. (My 88's quit sometime around 1999-2000.) They cost around $60, but you can get to them without a certified mechanic, if you take a couple of hours.
Truck is offline   Reply With Quote
Old 02-07-2006, 05:08 PM   #4
Chief Wiggim
Chief Wiggim's Avatar
My brothet had the same exact thing happen to his bronco II and it was his ignition module on the distibitor. He replaced that and it started right up.
Chief Wiggim is offline   Reply With Quote
