09-21-2005, 02:30 PM | #1 | |
D15 Bottom D16 Head
Does anyone here know if a D16 Head will fit on a D15 Block? I was told it would but im not sure if I belive it or not. Someone confirm the truth
09-21-2005, 03:16 PM | #2 | |
AF -Advisor
Re: D15 Bottom D16 Head
What year, which D15/D16? For example, the D16a1, D16A6, and D16Y8 motors all have different heads.
The only other head that will fit on the 84-87 D15A3/EW motor is a DOHC D16A1 head which is called a Hydra swap. You will however have to construct your own bracket for the timing belt tensioner pulley. This swap is for people who are up to a challenge and don't want to bother swapping the whole D16A1 motor. NO OTHER D-SERIES HEAD WILL FIT ON THE 84-87 D15/EW MOTOR! |
09-21-2005, 04:05 PM | #3 | ||
Re: Re: D15 Bottom D16 Head
I have the 87 D15A1 FI I have the SI CRX so is that different from the D15/EW |
09-21-2005, 04:07 PM | #4 | |
The Engine is a D15A1 In the Si Model
09-21-2005, 04:59 PM | #5 | |
AF -Advisor
Where does it say D15A1? The '87 SI came with a D15A3. Either way, except for the 1300cc, the stock engine blocks for any 84-87 Civic/CRX are all the same. The EWx designation was changed to D15xx in '87, the Honda D-series motor changed completely in '88, and Acura changed from D-series to B-series in '90.
Basically what this means is that if you've got the stock SI motor in your car, no '88+ Honda D-series head will fit on your motor. |
12-19-2005, 09:45 AM | #6 | |
what is the difference between the d15a3 head and the d16a1 head?
12-19-2005, 06:36 PM | #7 | ||
AF -Advisor
