08-13-2003, 06:55 PM | #1 | |
Putting a 400 into a 1980 Firebird
I have a 1980 firebird now with a 301 and a T350 tranny, Im wanting to put a mid 70's 400 with a T400 tranny into it. Will all of the engine mounts and tranny mounts line up? and is there anything else that I will need to do? any help is much appreciated
08-14-2003, 01:07 AM | #2 | |
the engine will mount just fine the tranny should as well i did the same thing in a 80 ta i had it was a long process but worked great and btw u might want to update the exhaust if u have not done so
08-14-2003, 01:58 AM | #3 | |
yah im planning on building the engine into a half day to day and half drag car
alright so I shouldnt encounter any problems doing this? |
08-14-2003, 01:36 PM | #4 | |
u shouldn' have any problems its not even a tight squeeze u r going to need some new bypass belts well i did i took out my ac since it didn't work and i put on a new fan u might need a bigger radiator i found one at a junk yard and they gave it tp me 3 core might work i had a 2 so i put a 4 in it if u have a 2 u need a bigger one other than thateverything worked.
08-15-2003, 05:12 PM | #5 | |
what would i need bypass belts for?
08-15-2003, 06:31 PM | #6 | |
more horses.
Reppin the D's.. |
08-15-2003, 07:34 PM | #7 | |
how so?????
08-23-2003, 02:18 AM | #8 | |
would it work with my current T-350 as well?
08-24-2003, 02:11 AM | #9 | |
your 350 t should bolt up to as well.. the less belts running = less strain on your motor= more hp.
08-24-2003, 02:34 AM | #10 | |
well it dosent have ac so the only other thing to bypass is the smog pump which ill take apart and then just leave the pully to spin freely
08-25-2003, 02:16 AM | #11 | |
i would just bypass that pully all together there pretty cheep for a bypass belt i think they were like 4 dollars a piece less pullys running he better pluss smaller belts are better as well. let me know how this process works out
08-25-2003, 02:18 AM | #12 | |
i will
but the pump still needs to spin cause if air care inspects the engine compartment i will fail it on the spot and i just hate aircare cause if u dont got the cats and that stuff it dosent matter what comes out the tail pipes you still fail |
