how much does a engine swap cost
ok, i currently have a 1994 firebird 3.4 l v6 with the 5 speed manual transmission and i was wondering how much it would cost to have the engine swapped to a v8 engine? could you guys please give me lots of details on everythign involved
Its something to think about on your side.
Do you want Fuel Injection? DO you want it to be a Carb. Do You have the time? Do you have the tools? Do you have a Nice wallet? Fuel Injection is going to be more expensive, you have to do all the wiring and have a computer and its just a big hassle. And the motors are going to be more expensive. Carb. You dont have to worry about the wiring as much as a Fuel injected motor. Motors are cheaper. Swaping, You will prolly need Stronger front springs to hold the extra weight of the 8 Cylinders. Not sure but you may need a new bell housing to mount the tranny up to the motor. NOT SURE. Your going to need new motor mounts. Prolly new front Sway bars I have heard they break when the motor is put in. Prolly new radiator cooling fans to accomidate for the more cooling needed. That is the basics I dont know if your trans will hold up, or even your rear end. Best bet would be to sell the car and get a car already with a V8 In it. I learned the hard way. I bough a V6 3rd gen car and I thought I could do it well.... Its not as easy as it looks. Its just better to buy the car already with the stuff on it. I ended up buying a GTA trans am ![]()
It depends on what engine You want. A new Ls1 will cost you 5000 for a cate engine while you could pick up a slightly older Lt1 for 2000. I am also looking at a new engine swap for my 84 trans am. It already has a 305 v8 but I want some more power. I don't want to buy a new car as I feel the new bodies are much uglier than the 3rd generation. Good luck with your car.
If its a new motor you're looking for Rakshas, I wouldn't bother with an LT1/4 or LS1 crate motor - get yourself a fast burn ZZ3 crate motor, that thing comes with 380 HP out of the box. GM has a lot of good crate motors that can kick ass right off the bat and really do damage if you get the heads done or drop in a stroker crank. I know a guy who got a ZZ3 for his C4 Vette (pre 1990) and as soon as he picked up the motor he took it right over to a wicked LT1 shop and got the heads ported & polished with 2.05/1.60 valves put in, DFI electronic fuel injection, and some other tweaks. Pulled over 420 HP to the rear wheels.
taylor2527 going from a V6 to a 300+ ft/lb V8 is going to involve some suspension and chassis upgrades as well. I couldn't tell you about the tranny and I don't think the rear ends are the same(but I could be wrong). Definitely look into all the costs involved. |
Yeah. Ive been looking around for a 383 stroked motor. The non emissions legal ones do about 538/495 hp/torque while legal ones do 435/465. Either way enough to smoke most people.
