2000 GMC C2500 Wont start!
20GMC00
02-07-2010, 06:34 PM
I was driving my 2000 GMC C2500 and it ran out of gas. I put gas in and now its getting fuel but wont start. It is the old body style with a 350 5.7. Any ideas? Thanks.
maxwedge
02-08-2010, 09:36 AM
How fuel pressure do you have at the rail, about 60 psi is required.
20GMC00
02-11-2010, 12:48 AM
It is right at 60 psi, and it holds 60 psi when the pump stops.
maxwedge
02-11-2010, 09:44 AM
Ok, will it start spraying carb cleaner into the intake, or try starting fluid.
20GMC00
02-11-2010, 07:12 PM
Tried the carb cleaner and nothing. There was power to the distributor but nothing coming out. I checked the cap and rotor and they are very coroded. I got all the little metal tabs cleaned off and cleaned off the blade on the rotor and now it tries to start. Think I found my problem though. Dont know how it made it this long being so corroded. Thanks.
Mycrofte
05-01-2010, 05:18 AM
I have the same problem with my 1997. I end up replacing the cap & rotor every November. If it is the same as mine, it is a poor design. There is no seal or gasket and moisture gets in but won't come out.
And those plastic screw holes are only good for alignment now. I have to put a plastic tie strap around the cap to hold it on...
2000 GMC Florida
05-11-2010, 10:45 AM
Use a brass lead cap and rotar and not a aluminum, last a little longer, same problem I had on a 88' GMC
