Help!!! 99 F250 SD diesel fuel leak
garyjh2
01-06-2010, 12:20 PM
Fuel is leaking from the drain tube of the fuel filter/water seperator. The drain lever is in the closed position. Fuel filter was changed a month ago. I cycled the drain lever several times, fuel still leaking.
fordtrucksonly
01-06-2010, 09:58 PM
Replace the drain valve assembly, fairly cheap from ford, easy to fix. Most late model 7.3's leaked with age.
garyjh2
01-25-2010, 08:01 PM
That did the trick. Stealership - $75.00
Thanks for your help.
