1998 Sububan Starts, then quits
michaelwalker
01-19-2009, 11:39 AM
It will start just fine then quit, no problems before at all..any ideas? thought it was a frozen fuel line, but it warmed up here in Wisconsin and still acts the same..
maxwedge
01-19-2009, 04:15 PM
Welcome to AF, this is the wrong forum I am moving this to the Chev Suburban forum.
sniper4x4
03-05-2009, 10:17 AM
My GMC does the same thing I thought it might be my fuel filter but that wasn't it. I'm still baffled but for me it is intermittent and usually it won't start up again normally until the next day. It make me no longer feel safe driving it since Its always in the back of my mind right before I start it "if it will happen again."
Good luck
brcidd
03-05-2009, 11:26 AM
When this happens- is the security light (on instrument cluster) on or flashing?
Normally the light should light and go out within 5 seconds after start....
sniper4x4
03-05-2009, 05:07 PM
My Security light in the cluster turned on today and stays on while driving but I'm not sure which issue it has to deal with I have a few. Please see this thread (http://www.automotiveforums.com/vbulletin/showthread.php?p=5928071#post5928071)
Today I replaced my TPS sensor per the AutoZone counter guy what the heck its only $30 and yesterday I bought a can of Mass Air Flow cleaner and I removed a thoroughly cleaned my MAF. I also replaced the Fuel Filter. I was also told to maybe try replacing the Kram Sensor (not sure of spelling) which he said was inside the distributor?
big tex84
05-03-2009, 03:08 AM
have the factory security system checked out, i was screwin around with my 04, and the security light came on, and it would start for 5 seconds then quit it is to do with the factory security system in my case, worth a shot though
aztecf
05-05-2009, 08:06 AM
Turn the key to the run position and let it sit like that for 10 min, that will reset the security system, you may need to do this a couple times.
Jeff
