84 ram 250 wat wire is fuel gauge
comet240
11-10-2008, 03:25 PM
hi i like to know what wire in the wiring harness that goes over the driver side roof to the back is for the fuel gauge i last year re rivoted the camper van and drilled holes in the wires i had repaired all of them but still dont get a fuel guage wire so i wannna re run a new wire any ideas how to trace it for me
alloro
11-10-2008, 04:48 PM
It's an 18 gauge light blue wire.
comet240
11-10-2008, 05:44 PM
ok thanks can u tell me if its the wire that then goes from the back of the van on drivers side to the passenger side? as this is converted campervan and i dont wanna take all the wood working off
and they never caucked the cab on then rivioted so now i just pealing the rust off damn ppl are cheap
alloro
11-10-2008, 05:59 PM
I'm not positive if it crosses over or not, but it appears from the wiring diagram that the fuel sender wire is in the same harness as the tail/backup lights; if that helps any.
comet240
11-10-2008, 06:11 PM
somewhat i just wanted to know where i could just by pass the wire near the back jsut wasnt sure if front wire was bad or not but ill try that tommorow as too dark now
comet240
11-12-2008, 09:49 AM
ok i traced it but not sure if the fuel pump float is working or not
but is the power from the wire from the gauge suposed be 0 to 6 volts flashing? or is it suposed to be constant 12 volts i know if i short the wire to the ground that the gauge is working but i not sure if the tank one is working or if its just cuz not enough voltage? any ideas or someone can measure the voltage on the line
