2000 CVPI How to check for ABS?
wgbtucson
09-24-2008, 04:03 PM
I have a 2000 CVPI. I thought it had ABS as standard equipment. The insurance guy disagrees based on the VIN ( higher insurance rate ). How can I tell visually if it has ABS? I prefer not to drive down the road and lock them up to see what happens. Thanks in advance.
way2old
09-24-2008, 06:43 PM
Jack and support the vehicle so you can crawl under it. If it has ABS you will see wiring going into the back side of the hub. Or look down beside the drivers side fender well and see if there is a large aluminum block with a lot of metal lines coming out of it.
