Door weatherstriping sticking
mike561
06-25-2008, 07:28 PM
If i dont open any of the doors in my car for at least a day the weatherstripping seems to stick to the metal and you can hear it peel off when you open the door, is there any type of light grease or something i can put on there to stop it from sticking so the doors open easier???
SLJ2137694
06-25-2008, 08:30 PM
Get some spray silicone and then spray a rag with it. Take the rag and wipe it on the weatherstriping and that should stop the sticking.
mike561
06-25-2008, 08:35 PM
will that dry out after a while?
SLJ2137694
06-25-2008, 08:41 PM
Yes, the silicone will need to be reapplied. The application of silicone is recommended to help keep the weatherstriping from drying out.
mike561
06-25-2008, 09:05 PM
yeah its not dried out, its still foamy and flexable, i geuss its just from the sun kind of baking it onto the metal
'97ventureowner
06-25-2008, 09:21 PM
We have a similar problem up North in the winter where the weatherstripping can stick due to freezing temperatures. I've used WD-40 or Pam non-stick spray to keep the weatherstripping from sticking to the metal.
silicon212
06-26-2008, 12:33 AM
Second the PAM. It's a kinda odd use for it, but it works!
j cAT
06-26-2008, 09:07 PM
i use silicone grease.....been using it for over 30years... use small amounts rub it into the rubber, wipe off excess...this should last 1 year...i use it because the weather strip will freeze to frame doors won't open in winter so every november this is done and it keeps the rubber like new..1984 camaro weather strip still soft no cracks..
SLJ2137694
06-26-2008, 09:52 PM
I prefer silicone grease also. It takes a little more effort to apply but it works well and keeps the seals like new. Just don't use a petroleum based lube on the weatherstrips as is may cause them to deteriorate.
mike561
06-26-2008, 09:56 PM
ok cool ill try that out, thx
j cAT
06-27-2008, 09:14 AM
this is a good thing to point out as some of the weather stripping will get distorted and swell up .....this I found when some oil from door hinge dripped on the weather strip....
'97ventureowner
06-27-2008, 09:43 AM
In that case couldn't you use K Y Jelly??:naughty: :rofl: :p
silicon212
06-27-2008, 12:34 PM
Nah, it's water based and will dry out! LOL!
bobss396
07-08-2008, 08:12 AM
Also clean the metal contact areas and wax them with plain old car wax. This should help, I do this with all my cars and it helps in the winter if it happens to ice up.
Bob
Bob
Blue Bowtie
07-08-2008, 10:04 PM
A third vote for silicone grease instead of spray. Door seals, trunk seals, the cowl seal, lower window sweeps, glass seals, window guide channels, radiator support air baffles, and suspension bushings all get silicone grease. I prefer the larger tubes of Permatex (#22058) or Fiske Brothers (#L251) silicones. If you have a 20-year old car with T-Tops or a roof window and want the original seals to work, you'll also treat those. Treat all the body rubber once a year and the seals will not bake on in summer nor freeze in winter.
