99 Suburban - Coolant Smell
and9800
05-16-2008, 07:45 PM
I can smell engine coolant when it's running, what should I test and or check (and how do I do it)? I don't have any codes, and besides a small exhaust leak, it runs fine. It was losing coolant for a while, but it hasn't lost any for about 2 - 3 weeks.
C2500 2wd
171,000 miles
7.4 engine
Auto with a/c
C2500 2wd
171,000 miles
7.4 engine
Auto with a/c
mini man 007
05-16-2008, 08:22 PM
hi and welcome to af you have a intake leak for shure check on the side of the intake and heads you will see it is wet if not look in the front of the motor just behind the fan
NoEcm
05-16-2008, 11:12 PM
Could be the lower intake manifold gasket but the 7.4L engines are not known for bad gaskets.
Besides a leaking water hose, I would also check the water pump, heater hose quick disconnect fitting, and heater control valve.
MT-2500
05-18-2008, 08:59 AM
If you can smell it it is leaking or has leaked.
Watch for coolant in the oil.
For hard too find leaks they make a dye test kit to put in the coolant.
Also a pressure test cold and war and hot.
Look on top and underside of everything that has coolant in it or running threw it.
Check from rad cap back to floorboar heater core.
Post back what you find.
MT
MT
