Your smaller machined part ;)
gionc
01-31-2008, 11:43 AM
This is mine: tyre's valvle.
http://i27.photobucket.com/albums/c159/gionc/machining/CIMG6173.jpg
Would be cool post also the bigger one!!!
cinqster
01-31-2008, 08:24 PM
Beautiful work G. You've really got your head around that lathe. Are you making more than one of them?!:grinyes:
Not my work (I've stolen the picture from Thunder Valley F1) but check out those nut and bolt heads on the sidecases at the back of the photo!
http://i208.photobucket.com/albums/bb224/cinqster-photo/287865788_d5aff45f55.jpg
I know that they're CNC'ed but how do they make large quantites of them at a time? I can't imagine working that small by hand!:banghead:
mikemechanic
01-31-2008, 09:42 PM
Cool Gio, how do you do that without it breaking off? This is one of the things I am struggling with at the moment. I find when I get under 1mm it breaks off.
Mike
Mike
its not unusual
01-31-2008, 10:20 PM
gionc
02-01-2008, 04:03 AM
(ALEKS: fantastic job)
Mike
I got the same problem until now: I guess some helps would be:
- you see that the thiny bit has a "big foot" with bigger diameters, this I guess help to contain if not prevents vibrations, my thought is that the minor diam. collapse for vibrations, but react well at longitudinal forces
- a perfect tuning of the cutter tool heigh: it must be exactly at the rod's center/axis
- since a thini diam can't afford a big force I used a 45° tool's bit, so it touch the alu in 1 only point
later I'll post some job's step, I seen you'll cut very thin diam (0.2 mm?) but not so long... I'm working on those factor since I need 6-8mm long wires (turned, comples form) by 0.2 mm diam ;) to do....... :D wire spoked rims :D
Mike
