92 GMC Sierra No power to fuel pump fuse.
RBTider
01-13-2008, 04:02 PM
The truck was working fine. Drove it to work. Left to go home, it wouldn't start. Changed fuel pump, filter, relay and oil pressure switch. Further troubleshooting revealed no power at fuel pump fuse.
Where does this fuse get its power? The Haynes manual is vague and shows an orange wire going to it. There are 2 gray wires. Any help will be greatly appreciated. Thanks.
maxwedge
01-14-2008, 02:19 PM
Welcome to AF, check the wiring diagrams at autozone.com, repair guides. Look under chassis electrical.
RBTider
01-14-2008, 08:51 PM
Thanks. I went to Autozone.com. Unfortunately they do not list a repair guide for a 92 GMC or Chevy.
mansopoor
01-15-2008, 12:41 PM
here is one thing you can do!. run a wire from a power source to the fuse (power side), and see if the pump kicks in.
tempfixit
01-15-2008, 02:04 PM
Look here for diagrams:
http://www.autozone.com/az/cds/en_us/0900823d/80/08/79/51/0900823d80087951/repairInfoPages.htm
Sometimes you need to look up parts: For instance I looked up fuel pump for 92 GMC and found the online manual.
Hope this helps
Hope this helps
