Bleeding the Brakes
1993Suburban
12-09-2007, 11:10 PM
What is the proper brake bleeding procedure for my 1996 Suburban? Also if I only replace one caliper, do I need to bleed all the brakes or just the caliper I replaced? Thanks!
tempfixit
12-10-2007, 02:36 AM
This thread should help you on bleeding procedure:
http://www.automotiveforums.com/vbulletin/showthread.php?t=753684&highlight=brake+bleeding
I believe you should only need to bleed the caliper removed unless fluid reservoir became empty at some time.
Good Luck
