rear lights inop
stuk2000
11-22-2007, 01:30 PM
can anyone please help me, my rear lights have stopped working, brake light works, indicators work and fog. but when i put my lights on they dont show at the back, where should i start to look etc, fuses??
Will12
11-27-2007, 09:15 AM
I had similar problem with bad connection in bulb (over the time the lead became squished); I changed the bulb and it was O.K. ever since.
ricedarian
11-30-2007, 01:50 PM
You should start to look on some specialized websites or ebay or something...call around for vw specialists until then I know of a website that may help you out with rearlightss I have a directlink http://www.myhotvw.com/volkswagon_parts/Headlights_Tail_Lights Good luck tell me what you think
younes424
09-21-2008, 01:48 PM
i had the same problem, i just took out the light switch and put it back, i don't even know how that happend, but the tail lights started working again and they're still working til now (more than a month)...check your light switch..
70GTORAG
09-24-2008, 10:26 AM
I have a 99 passat just at the dealer yesterday for an oil change and they noticed my tail lights not working. They diagnosed the headlight switch faulty, new part $201.00. The old switch is not repairable as it is a circuit type switch(electronic). All other lights working, just not tail lights.
70GTORAG
11-03-2009, 02:20 PM
FYI. I replaced the headlight switch with a used one back then and it was working fine for a year until now. The problem now is the driver side headlight stopped working. Have tried to replace headlight but no change. I think it is the headlight switch again.
