gas gauge want go up
dss-spoiledboy
11-04-2007, 06:25 PM
I ran my 2001 2500 suburban with a 8.1 til the gas light came on and went to fill it up and when i started it up the fuel gauge went up and then after 30 sec went to E and the gas light came back on so when you turn it back off and leave it for a min and turn it back on it will go up and come right back down so does anyone have any suggestions on what wrong!!!!!!!!!
horse482
11-07-2007, 10:43 PM
Welcome to af. It could be the sender in the take is not reading the level correctly, or you could have a stepper motor going bad in the cluster. If the stepper motor is going bad talk to your local dealer, there is a problem with them and gm and delphi is paying to have the problem ones replaced. I am not sure what years this covers though. Hope this helps.
dss-spoiledboy
11-08-2007, 01:13 PM
Thanks for posting but i got it fixed wed the sensor in the take that sends it to everything went bad and just that sensor was 11o.00 so i asked what a fuel pump with it on it would cost and we said 220.00 so i replaced it and it works fine now!!!
