Heater blower switch only works on high-Alero
sxdc
08-14-2007, 11:07 PM
I have a recently purchased a 2002 Olds Alero. I noticed the heater blower motor only works on high and not the lower settings. Quite annoying actually. So I picked up a used switch from a wrecker, changed it, and the replacement switch does exactly the same thing. Also my service engine soon light is on. I haven't had the codes scanned yet, but is it possible the 2 are connected? I've read in some forums that the ignition switch can be the problem. Will that really prevent the blower motor from working on lower settings?
Thanks
xeroinfinity
08-15-2007, 08:48 AM
It is your blower motor resistor, if the fuse is good.
Has nothing to do with your Service light.
Here is the procedure for replacing the resistor, it says its for the Grand Am but its all relavent to your Alero.
Blower Motor & Resistor Removal - 99+ Grand Am (http://www.automotiveforums.com/vbulletin/showthread.php?t=665246)
You will have to have it scanned to find out why the Service light if on .
sxdc
08-15-2007, 09:22 AM
thanks for the advise. I will check into this resistor and let you know.
sxdc
08-17-2007, 09:03 AM
Thank you Sir. That fixed the blower motor problem. Now I can enjoy the lower settings. The part cost about $35. and about 30 minutes to replace.
Thanks again. Cheers
xeroinfinity
08-17-2007, 09:10 AM
Yea the factory resistors were crap !
Shouldnt have any problems with the replacement.
you are welcome :D
