Oil Pump
Kawazar
07-08-2007, 10:09 AM
I need to do the oil pan on my 94 1500 with the 5.7L. While I am there I thought I would do the oil pump too. I noticed there is a OE pump, a high volume pump and a high pressure/high volume pump. Any reason why I should use anything but standard? I have 149K on the motor now and I'm not sure if there would be any benifit on a stock motor to using any of the other pumps.
sub006
07-17-2007, 02:13 AM
The hp pumps will probably cost you some power and mileage to turn them, compared to the stock one.
If you've got 30 pounds or more, well warmed-up at highway speeds, you don't need more pressure. Excess pressure is only good for causing oil leaks!
taillight
07-17-2007, 08:49 AM
Go OE unless your going to run it 1/4 mile on sunday.
Kawazar
07-17-2007, 08:36 PM
Thanks guys.
