I hear water/sloshing noises when I turn, what can I do?
Jase_Sir
07-04-2007, 05:12 AM
I know this is posted in the FAQ section but the links don't work.
I hear sloshing noises when I turn corners in my CRX del sol. upon inspection ion my boot I find water above the rear passenger wheel arch. It seems to be coming from behind the drivers seats, somewhere behind the rear speakers.
Is this a common fault?
Does anyone know how I can get rod of the water and plug the leak?
Thanks
Thanks
AudioGuy93DelSol
07-04-2007, 01:20 PM
Bam (http://www.elneckio.com/stuff/crx/sloshing/interiorremovalpipeclean.html). That should do ya.
TheSun95
07-13-2007, 09:16 PM
Thanks
I have the same problem. I have visited the link and took apart the rear of the car and followed the instructions up to removing the thin metal plate. It did not come off easily and rather than bend it and worry about resealing it I scrapped the idea of fixing the water noise and put in an amp and removed my original cd changer.
Recently I had the water leak under the dash durring turns and found I could fix it by getting under the car and shooting air into the drain tube with my compressor. That worked very well and I am assuming that the rear window sloshing could be fixed the same way. If there is a clogged drain hole as in the elneckio fix then I assume there is an exit under the car somewhere. Problem is I can't find where that somewhere is.
If someone here doesn't come up with something soon, I think I will try the British suggestion and try the side skirt fender plug thing.
Thanks
