1997 Yukon Loss of power
rican4lfe
02-15-2007, 05:36 PM
When going up hill it seems to loose power and gets very lazy, once up hill power resumes and everything is good again.... Fuel preasure regulator problem????? Fuel pump going bad??????? Completely new tune, new fuel filter and air filter... Currently onboard I have headers, air intake and trottle body separator.
2000CAYukon
02-15-2007, 05:57 PM
What is the fuel pressure at? Check pressure cold with engine not running. Then with engine running both cold and warm. Turn the engine off and watch the pressure for 5 minutes.
Any codes stored? Even if the check engine light is off, you should get it scanned.
Has the intake manifold gasket ever been replaced?
//2000CAYukon
//2000CAYukon
rican4lfe
02-17-2007, 08:59 AM
Never had check preasure, but will and post results, no significant codes..... Currently plan on rebuilding engine in Mid March. Looking into boosting around 350 HP. Hopefully this will aliviate the problems. Thanks for the tips
Tankster
02-21-2007, 12:40 PM
What are the signs that you have to replace the intake manifold gasket?
Thanks
Thanks
2000CAYukon
02-21-2007, 01:47 PM
Thanks
Tankster, the reason I asked about the intake manifold gasket was because the timing is not set with a timing light. Many times after the intake manifold gaskets are replaced and if the cam retard is not set with a scan tool, misfires can happen causing power loss under load.
On the Vortec engines 96-99, it is common for the intake manifold gaskets to leak coolant.
//2000CAYukon
Thanks
//2000CAYukon
Tankster
02-21-2007, 02:45 PM
Oh I see.Has anyone had the TBI gasket go? What does the truck do when it goes? '95 yukon
Thanks
Thanks
2000CAYukon
02-21-2007, 04:27 PM
Thanks
When mine went I had a pretty high idle. Basically is creates a vacuum leak and the ECM tries to compensate for the extra air entering the system (it sees the system running lean so it adds fuel).
//2000CAYukon
Thanks
//2000CAYukon
afsfcop
04-13-2007, 05:30 PM
We had this happen w/ our 97. We got it back in 98 and took it back to the dealership. At the time GM came out with an advisory(not necessarily a recall) that addressed this problem. They recommended a complete tune up, that the dealer took care of for us. Since then we haven't had any problems.
Hope this helps!
Hope this helps!
