93 S10 Blazer 4X4 battery drain
gpmodelj70
11-20-2006, 01:04 PM
My 93 S10 Blazer is driven once a week...battery runs down every 3 or 4 days...had battery load tested and it is ok...I checked amp draw with battery in truck and have a 14mA constant draw with everything turned off...any ideas what it might be...installed a new alternator 2 years ago...problem has just started happening in the last month...:banghead:
stv840
11-20-2006, 04:26 PM
you will have to pull the fuses 1 at a time untill the draw goes down to see what circit the draw is on because 14 mamps is to much should be less than 5
forever3
11-20-2006, 07:17 PM
you will have to pull the fuses 1 at a time untill the draw goes down to see what circit the draw is on because 14 mamps is to much should be less than 5 good idea !!!!
