Seat belt waring buzzer
hocbj23
09-08-2006, 12:44 PM
I have a 1992 Mazda B2200 LE regular cab short bed.It is my understanding that the truck has a warning buzzer for key in the ignition /seat belt unbuckled. There is a factory "TIMER/BUZZER" module under the dash in the correct spot. I replaced it thinking it was bad, but still no warning buzzer.The timer part is working as the seat belt lite comes on for 3 seconds and then goes off.Can anyone help re getting the buzzer part to work?Thanks. BJ
Pootz22
10-21-2006, 10:54 AM
I have an '86 and I pull the buzzer out because it was annoying. It was a 2"x3" black box under the dash behind hood release lever. If you replaced it with a new one and it still won't work I'm not sure of the issue unless a fuse is out.
archer of loaf
10-21-2006, 05:31 PM
Here is a funny story - Perhaps it will solve your problem. My seatbelt was not clipping in well (drivers) and oneday I sprayed some Wd40 into the unit. The next time I jumped in and turned her over (1990 B2200) this horrible buzzing sound was there - the seatbelt sound now worked as I was not buckled in. It has never made that sound before.
I hope this may be of help as you are a great help to all of us here!
hocbj23
10-23-2006, 06:05 AM
Thanks for the input.I did check fuses and all were ok.Archer ,I did not think about a faulty seat belt connection which could cause the buzzer not to go off.I admit the buzzers are annoying including the one I installed last week to remind me the lights are on. However,I am reaching the age when I would forget my head if it were not attached to my shoulders so the buzzers are beginning to assume positive significance.Lol. Thanks again for the suggestions. BJ
archer of loaf
10-23-2006, 07:27 AM
Yes - the lights are a problem i always seem to leave mine on too! At least I am not the only one here!
Cheers.
Cheers.
hocbj23
10-23-2006, 09:21 AM
There is a great thread on MazdaTruckin.com that shows how to put a lites on warning buzzer in ur 2200 if u want to put one on >bJ
