Water leaking inside
spinning
09-04-2006, 09:33 AM
I have a 97 Ply Voy , latly been getting water leakage inside when it rains , front under dash and driver side rear pasanger side can see water comeing down from molding an when you bull the seat belt is wet driver an pas rear .
slatersmac
09-16-2006, 08:08 AM
check the drain hoses on the pan under the front windsield. They get clogged and water overfills the pan and run up behind the dash. i had the same problem in my 96 voyager and when i cleaned the drain hoses, problem was solved.
lkrypel
11-29-2006, 02:48 PM
I have had the same problem but it persists even after I clean the drain hoses.
RIP
11-29-2006, 03:15 PM
Soak it up with a paper towel. If the towel has a green tint and/or it's slimmy then it's coolant. Most likely the heater core is leaking and needs to be replaced.
