Brake Lights On An Aerostar
queenston
06-02-2002, 09:44 PM
I have a 93 Aerostar. The brake lights on each side don't work. The light at the top of the van does goes on when the pedal is depressed. I have checked the fuse, it is fine. I have also checked both light bulbs and they are okay. What am I missing?
fordman123
08-17-2002, 01:54 PM
You may want to check to see if you are getting voltage to the brake lamp FROM the multifunction switch. Seen alot of those cause that problem. Hope this helps
fordman123
INIRTS2
11-20-2005, 01:43 PM
I also have a 93 Aerostar. When you say light at top, do you mean the amber above the red or perhaps a brake light UP above(diff. model).
Mine is XL,the reason I wonder is i had heard that brakelights and
cruisecontrol are tied in this partic.model.
