1995 Plymouth Acclaim Brakes Spongy
ragrone
08-15-2005, 06:28 PM
I replaced the front brakes, rotors, calibers, pads about two weeks ago. Over the weekend the pedal traveled all the way to the floor with no visible loss of fluid.
Today I replaced the master cylinder and still the same results the pedal gets spongy when the engine is turned on. Otherwise during normal bleeding procedures the pedal appears very hard (good).
What to do?
theFREAKnasty82
08-17-2005, 10:19 PM
did you bench bleed your master cylinder prior to placing on the car? If not, you've trapped air in your system and now you'll need to bleed out all four wheels to get out that trapped air that has been placed in your system.
ragrone
08-17-2005, 10:59 PM
ydeah thanks did that turns out there was a bad brake line to the right rear brake.... tiny leak but good enough to cause the problem... all repaired
