camry 00 noise from the front suspension
techm
07-06-2005, 12:37 AM
Hi all,
I bought a "certified" 2000 camry and for some time now I hear a noise (like squick, metal into metal type) when going over bumps. I went to the dealership and left them the car, they called me and said that they couldn't hear anything. I spent some time with the tecnician, but couldn't get it to produce the sound consistently, only a couple of times, which he said he didn't hear ... Anyway shortly after that I saw a bulletin at alldata and searcing through forums including AF I found lots of information about a noise in the front suspension that maybe the same as the problem I'm having.
I have the extended warranty which expires in 6 months or so. I was wondering if I can get help from anyone that has had the same problem.
1. How do I help their hearing? The noise can be heard when going over bumps, but I can't reproduce it by let's say pushing the front down by hand and also the dealership doesn't have a terrain that can be used.
2. Since this (or similar) problem is described in a technical bulletin can I get them to fix it for free - if I'm lucky it maybe covered by the warranty.
Thanks in advance for any comments and/or ideas.
scotty38356
07-07-2005, 04:52 PM
yes, your problem is covered by your extended warranty. the problem is the strut tower mount. the only way to reproduce the sound, which i must admit is the most annoying sound on earth is to hit a bump in the road, occassionally several times.
i believe there is a TSB for your year model camry, so you can remind your repair man of that. that often unclogs their ears, because they dont want to be sued.
Hi all,
Shak1996
09-20-2007, 11:57 AM
Can you tell me where I can find the bulletin. My car does the same thing. Thanks
