88 bronco xlt fuel pump location?
huckaday
05-29-2005, 02:34 AM
Can anyone please tell me where the fuel pump is located in a 88 bronco xlt? (351 engine) Is it in or out of the tank? Just wondering what the repair bill is going to be like after the tow bill! She just quit on me tonight, just like I was running out of gas... and then wouldn't start again... turned over fine, power seems to be fine, just not getting any fuel it seems.
Thanks in advance.
Truck
06-01-2005, 11:46 PM
OMG, I'm so sorry to hear that.
You have two. One is on the frame rail, in front of the fuel filter. By in front of, I mean as the fuel comes from the back, so it's behind the filter as you look at it. I hope this didn't fail on you.
The other is in the tank, with the fuel sending unit. (Which reads your gas level.) You have to take the tank off to get to it, and the Unit (with Sending Unit) costs about $120, the last I looked. The Pump without the Unit costs about $100. (But there's all that tank business you'd have to pay for.)
The worst part would be if the second pump failed. (As it did in my '87 302.) I spent a few hours stuck with it, then went to look at buying a whole new power train because I had no idea why the thing had quit....turns out that one of the two electrical leads had fallen off the pump. JUST FELL OFF. It was a matter of reconnecting the wire, and turning the little nut tight. Check for this problem before you comission any work. (A garage will soak you if they can...and nearly anyone can learn to fix old Fords!!! :) )
Green Beret
08-28-2006, 12:39 PM
Have a 88 bronco full size 302, Cant find outer fuel pump?
Any detailed info on were it is, Besides next to fuel filter.
jem270
08-30-2006, 03:29 PM
Under the driver door side next to the frame. Follow the fuel line from either the Throttle body or the tank and you will find it. Cylinder looking thing with electrical wires. The one with no wires would be the fuel filter. I have an 88 also.
89Bronco4x4
01-06-2007, 10:14 PM
Im sure yall have already figured this one out because this is an old thread however i have 89 Bronco 4x4 with a 302 and i have 2 fuel pumps. one is in the tank and one is outside. Im not totally sure if the 88s are the same. Sorry if this is not any help, like i said i know its kinda late.:rolleyes:
twofastinfuriated
01-16-2007, 01:13 AM
i wouldnt go to a shop if u have any mech. knowledge at all tho...u'll save a ton of money and time if u just buy a haynes or chilton manual and find it urself, its not that hard i promise
