5 lug conversion?
s13dr1fter
05-17-2005, 01:34 PM
I have a s13 and i want to do the 5 lug conversion. Does anyone know what parts i need to do this swap?
Scope240
05-17-2005, 05:22 PM
search the forum theres a lot, it been go over more than enough, and people do feel like restateing. in a nice way
s13dr1fter
05-17-2005, 06:22 PM
so if i get the rear hubs off a 300zx na or a 240sx se they will bolt right up to my s13?
burnout 180
05-17-2005, 06:47 PM
why do so much people want to convert from 4 lugs to 5.
Is it just because more rims are 5 lugs or is their a real advantage to doing this
orestes
05-17-2005, 06:49 PM
easier to get nicer rims and better brakes.
sidewayzS13
05-17-2005, 06:55 PM
more is better maybe?
240SXSlideStar
05-17-2005, 09:00 PM
More connection points to the wheels and since the wheels are connected to the single most important part of the car.....
orestes
05-18-2005, 12:49 AM
and its better to tighten lugnuts in the star pattern which you cant do with 4 lug.
monooxide
05-18-2005, 10:31 AM
Actually to get more accurate precise torque Square patterns are better....Torque one, go opposite, go to the one to the one right of that one, then accross from it and torque it down in Increments is much more accurate then a Star pattern could get.
s13dr1fter
05-18-2005, 11:59 AM
Hey guys not to be an ass or anything but i need help with the conversion, not tightening the damn lug nuts.
240SXSlideStar
05-18-2005, 12:30 PM
www.pdm-racing.com has got you covered on the conversion.
KaisenH
05-18-2005, 01:37 PM
I wrote this on 240sx.org a little while ago, has all the info you need if you are doing a 5 lug swap with s14 se components.....and im not bashing af.com but the 240 section kinda blows. Anyone who ACTUALLY OWNS a 240sx and doesnt have a bunch of noob questions should think about joining it. The people their really do know a lot more about 240's there. anyways....
« Re: I have a question about a 5 lug conversion?? 9:42 AM 5/13/2005
well for the rear you just need to the 5lug hubs, it is also easier if the bearings are still pressed on. This way you dont have to press your s13 bearings off and attach them to the s14 hub. For the front everything gets a little complicated, if you are using s14 front hubs you will also need the s14 front spindels. As the s14 bearings/hub are one unit and connot be pressed out. Now since you have to use the s14 hub and spindle you also need to either use the s14 balljoints from the junk car or buy some new ones. In addition to all that you also need the s14 bolts that connect the spindle assembly to the struts (or coilovers). This leads to another problem, the s13 strut bolts are around 12mm i think, and the s14 strut bolts you must use are 14mm. So you must take your struts (or coilovers) and drill the mounting holes out using a 14mm or 9/16 bit. Its not hard if you have a drill press, did all 8 of my holes in about an hour. Thats pretty much it, but you also have to remember you are now going to need 5 lug rotors as well. Also this is just for the 5 lug conversion off a 240sx se, i dont think it is the same for using 300zx parts.
ghostchild316
05-21-2005, 10:01 AM
My car-
http://i3.photobucket.com/albums/y66/ghostchild316/DSC00484.jpg
http://i3.photobucket.com/albums/y66/ghostchild316/DSC00486.jpg
http://i3.photobucket.com/albums/y66/ghostchild316/DSC00483.jpg
