Please Help!!! My probe is flooding with gas and will not run
jessicam
05-06-2005, 10:15 AM
I dont know what is wrong with the car. There was a problem with the fuel pump relay...it was replaced and it ran for about 30 mins, then wouldnt run. I had the check engine light scanned and it says that fuel system 1 and 2 is open...i do not know what that could be. Now when it is started there is a very strong smell of gas...then after 2 mins it stops running. After like 20 mins it will start again, then stop running. Can someone give me some advise on what could be wrong!
joshs93gt
05-06-2005, 04:52 PM
did your mechanic check the ohms on the relay? if it doesn't match right your car will not run right. that's all i can think of at the moment. good luck
