94 Surburban - no back up lights
Scott DeVillers
03-28-2005, 06:27 PM
My back up lights on my 94 burban are out. Bulbs are good, and I just replaced the Park/Neutral/back up switch but still no lights. Any idea's were to look next?
TrailLeadr
03-29-2005, 05:57 PM
You might want to see if the switch is set correctly. Those switches have alot of play in their positioning. Otherwise grab yourself a volt/ohm meter and start checking voltages and tracing wires.
Best of luck :thumbsup:
snowduck
03-30-2005, 04:33 PM
Just a thought, but my "95" rear tails went out and it was the ground plus a connector block under drivers rear by the hitch,corroded wires.redid wires with silicone sealer,havent had a problem since.
BTW also affected the trailer lights.
Hope this helps.
Ed
