92 sts Blower Fan runs continuously!
ho1mes
01-30-2005, 11:25 AM
92 sts blower fan runs continously...is there a relay to replace?
shuts off when the fuse is pulled.
baron1701
07-03-2007, 10:46 AM
*BUMP*
I am buying a 1994 SLS that has the same problem. Started after the heater core died.
DFBonnett
07-04-2007, 06:36 AM
The blower control module is likely bad. Not sure if your module is separate or intergral to the blower motor.
mnrumpole
07-05-2007, 09:30 AM
I too have a 92 with a blower fan problem. It makes a squeeky sound then stops. Does any one have a spec diagram to help me replace it? thanks in advance.
baron1701
07-05-2007, 02:10 PM
I think that on my 1994 SLS the blower motor control module is part of the blower motor. I just bought this '94 SLS for $400 as a replacement for my Oldsmobile Aurora that my wife trashed. I have nearly rebuilt that car and this seemed very similar. The car blew a heater core a year and a half ago and the owner tried his best and installed a new core. After the install, the car wouldn't charge (alternator code) and the blower moter will go on whenever plugged in.
Is the blower motor provided voltage all the time and just told what speed? If not, the climate control module is bad. At least thats my feeling for it. I still need to put in an alternator, water pump belt and pulley, and some genaral maintenance so I do have some time to mull over on this one.
BTW, behind the glove is a mess. The vents and actuators are jost hanging in place. Does anyone have any pics as to what it should look like behind the glove?
