What is V-Tec???
Boosted92HB
08-11-2004, 07:59 PM
I know that its good, and I know that it can be adjustable. I just dont understand what actually happens to the internals, injectors, etc... Does it just make a richer fuel mixture? I have no idea... NEWB.
CivicSpoon
08-11-2004, 08:37 PM
Search Newbie
sageuvagony
08-11-2004, 08:40 PM
VTEC is where.....at a certain RPM (5,000) for example, oil pressure activates a pin which activates the bigger lobes of a camshaft to open up the valves more for more air/fuel. I'm a lil tipsy right now... so bleh...
CivicSiRacer
08-11-2004, 08:41 PM
Basically is like having an economy motor and high strung motor in one.
On the SOHC the VTEC is only on the intake (if I remember right). At a set rpm point more air is let into the engine to increase performance.
On the DOHC VTEC the intake and exhaust open up for better breathing. There is definitely a better explanation searching http://www.google.com or http://www.howthingswork.com
Shaguar47
08-11-2004, 08:45 PM
It stands for Variable Valve Timing Electronic Lift Control. It's a system of cams and valves that pretty much give the extra boost to the engine when needed. It usually kicks in around 5k rpm's with a very slight kick and from there on your in a powerband of power. Oh and it's spelled vtec! :thumbsup:
xproductionz
08-12-2004, 05:34 PM
hmm....
untamedcivic
08-12-2004, 07:31 PM
don't hear this question everyday... go ask a local import shop. they'll tell you all you need to know, and try to sell you something. but it's all in good marketing :iceslolan :2cents:
GScivic7
08-13-2004, 05:05 AM
everything you need to know about VTEC can be found here http://www.leecao.com/honda/vtec/
Miataracer
08-14-2004, 08:29 AM
you dont know what vee-tack is, yet you want a turbo gsr? :disappoin
