'98 Windstar Rear A/C Blows Hot Air, Lower Vents Only
bear549
07-08-2004, 07:45 AM
My '98 Windstar rear A/C blows hot air only through the lower vents. I removed the rear panel, & the vacuum motor for the door is not operating. I traced the vacuum line to what appears to be another vaccum motor on what appears to be the water line from the heater core, maybe. I removed the vacuum line from this motor(?) and there was very little vacuum when the dash switch was activated. Any help would be appreciated.
ModMech
07-09-2004, 12:01 PM
You need to inspect the dash controls. Check for vacuum in and out AT the controls.
Unfortuneately, my FSMs do NOT include a vacuum routing diagram. Thanks Ford!
75Fbird
10-11-2004, 08:50 PM
I had the same problem. I changed the dash control for the rear AC/heat and it solved it. It's very easy to do - took about 10 minutes.
PossibleSideEffect
10-13-2004, 09:10 AM
What was the approximate cost for this fix?
I have the same problem.
DMS825
10-13-2004, 02:58 PM
I purchased the switch assembly for my 98 windstar in April 2003. Part number then was F68Z19986AA, cost was $22.42 from the local Ford dealer. They had it in stock. It is an easy repair once you figure out how the get the switch out of the dash.
redundant2
05-16-2007, 10:04 AM
I'll second this. I had exactly the same problem on my 98 Windstar and replaced the rear air/heat switch assembly on the dash (same part number F68Z19986AA). Works great now. Thanks for the advice guys and/or gals :)
