Couple of maxima questions
hovz
06-17-2004, 08:40 PM
just got my 1996 maxima se like a week ago. few questions
1. shifting to first gear and second is sometimes not smooth. it doesnt grind at all but i have to push a little and it feels a little choppy. id say maybe half of the time i shift this happens, other half it goes in easier. this is my first stick car so i dont rly have a point of reference if this is just how sticks are.
2. i want to get a tune up but i want to you high quality plugs and stuff for better performance. can i just bring my car to a mechanic and they will have performance plugs? or do i have to buy them myself. i have zero knowledge when it comes to doing this kind of stuff myself.
3. is it always hard to shift fast when first learning a stick? it takes me a little over 1 second to shift, maybe 2. is shifting fast something i will learn? or is it cuz of the problem i mentioned in my first question. also if i just push my shifter harder to shift faster will i damage my car?
hovz
06-17-2004, 09:04 PM
i live in LA, by venice blvd and wade. anyone in the area know any reliable mechanics? i just moved here from MA
95maxsewv
06-17-2004, 11:37 PM
man go out and get a haynes manual or something they are like 15 bucks and will help you out greatly. changing spark plugs in the max is easy as long as you have a long extension on your ratchet. it might take you a half an hour to an hour to change the plugs and air filter and oil the first time. but after that you know how to do it.
hovz
06-17-2004, 11:52 PM
anyone can help me with my other questions?
95maxsewv
06-17-2004, 11:53 PM
my 95 se seems a little sticky on the shifts sometimes too.. yeah it takes a little while to time the shifts right and to do it quickly
hovz
06-18-2004, 12:04 AM
it doesnt mean i will need a new transmission does it? cuz thats so much money
turk66460
06-18-2004, 03:13 AM
Ok people hard shifting caused by 1 or more things. Since the maximas have a hydralic clutch you might need some fluid in there ( BRAKE FLUID). 2 it might need to be adjust on the clutch pedal, and 3 is might need to be bleeded up front.
hovz
06-18-2004, 01:43 PM
Brake fluid is full, just added it when i bought the car. so thats not it.
are 2 and 3 covered in a tune up? and if not how much do they usually cost. can u give me a ballpark?
turk66460
06-18-2004, 05:18 PM
You can have your local mechanic do that not so expensive just like bleeding you brakes. Adjusting your clutch takes about 10-15 min first time. Not so hard both you can do it. But if you want a mechanice do it should not cost above $100 at the most.
