Bearings and turbochargers
NSX-R-SSJ20K
05-05-2004, 04:40 PM
What sort of bearing is appropriate for use in a turbocharger spinning at up to 150000rpm with a shaft diameter of 10mm?
DJJC
05-11-2004, 05:49 AM
ceramics. only ceramic bearings can be used on the the first car to break the sound barrier and still be running at 22 C the whole time. so if that isnt a test, i dunno what it.
flylwsi
05-11-2004, 08:52 AM
more specs on the turbo?
ball bearings aren't bad, ceramic is the shizzy.
NSX-R-SSJ20K
05-28-2004, 05:11 AM
ceramics is material not type. The type was rolling bearing. Go figure but any faster it would have to be special Gas turbine rolling bearing.
