Camry 97 Brakes squeak
makaveli3004
04-10-2004, 05:32 PM
hey recently i have nocited that when i apply the brakes on a normal stop the brakes squeak. the squeaking is even worse at faster speeds and with more people in the cr. i was wondering is there anything i could use to stop the squeaking or should i bring it to thedealer to havei t fixed
Joe W
04-10-2004, 06:45 PM
They will probably tell you that it is normal after they charge you for a brake inspection.Unless it is truely excessive in which case it could be a warning from the squealers built into some pads.Disc brakes are prone to squealing.
Brian R.
04-10-2004, 07:37 PM
If you just replaced the pads, might be the brand. Use Toyota brake pads. They don't normally squeak. Aftermarket pads often squeak.
