Newbie with a/c question
Paul H.
03-09-2004, 07:09 PM
Hi everyone, my wife has a 97 cutlass that has had a reoccurring problem for the past few years. The a/c is intermittant, meaning when you push the a/c button it will come on for a little and then turn itself off. The button sometimes have to be pressed several times to get it back on only to go off again. The fan works fine at all speeds. Could this be an easy fix? Thanks for the help.
92958jl
03-12-2004, 10:33 PM
Can't say for absolute sure without testing pressures but it sure sounds like the system is undercharged or overcharged. I would have to lean toward undercharged by what you described.
The only sure fire way to know if that is the problem though is test pressures.
Hope this helps
