1998 4cyl Camry
jamc20
08-22-2015, 11:35 AM
I have recently purchased a 1998 Toyota Camry 4 cyl. I had to replace the water pump as it was leaking coolant, I also changed the front and rear brakes and also the front rotors. As I was driving it after the brake change I noticed that I would seem to lose power, kind of like it wasn't getting any fuel or something. My rpms would go down, but most of the time would quickly rise again when I pushed on the gas. Any ideas on what my problem might be? Any help would be great!
Brian R.
08-22-2015, 12:32 PM
See if you have any codes in your ECM.
jamc20
08-24-2015, 08:38 AM
I plugged it in and got three codes P0401: exhaust gas circulation flow excessive detected, P1133: air/fuel circuit response bank 1, sensor 1, and P0171: Air/fuel mixture system lean bank.. I obviously have a air/fuel problem but I am honestly not sure what any of these mean.
Brian R.
08-24-2015, 09:22 AM
It may be that some of those codes are old. Reset the ECM (delete the codes) and drive it for a couple of days. Then check the codes again.
