1984 Cutlass supreme brougham steering colum issue
Richard S
04-02-2013, 08:39 PM
I have a taken the column apart to fix some issue and I have a spring that I recognize but fell out and cant remember where it goes. I have looked at diagrams but they are not clear enough to tell. I have tried to attach a picture I dont really know what Im doing though.
MagicRat
04-02-2013, 08:49 PM
Does it look like one of these?
Clickie (http://www.google.ca/imgres?imgurl=http://store.stepvanparts.com/PICS/GM-TURN-SIGNAL-CANCEL-SPRINGS-36901.GIF&imgrefurl=http://store.stepvanparts.com/GM-TURN-SIGNAL-CANCEL-SPRINGS-36901.HTM&h=248&w=300&sz=8&tbnid=N_FhlqsUKlnWKM:&tbnh=88&tbnw=106&zoom=1&usg=__-YmanMg4YnYzegZGLRplgvcq5rg=&docid=buILtePt-BB_qM&sa=X&ei=WYpbUeL8H8nD2AXlzoCwBw&ved=0CDgQ9QEwAg&dur=146)
Richard S
04-02-2013, 09:35 PM
48546 This is picture of what it looks like.
gmtech1
04-03-2013, 07:54 AM
Kinda looks like the spring for the key buzzer switch...the little plastic switch the slides in the hole under the ignition lock cylinder.
Tech II
04-03-2013, 11:55 AM
That GMTech1 guy is good!!!!!!!
gmtech1
04-03-2013, 01:56 PM
:smile: I used to rebuild those on a fairly regular basis...
Richard S
04-03-2013, 05:59 PM
I have that plastic piece with the two tangs coming out in the groove under the switch. I have tried everything I can think of to put it with that, because thats what I thought also but cant get it to go.
Richard S
04-03-2013, 07:26 PM
Many times over thank you for your help. You were absolutely correct. I had to walk away from it for a bit and went back and got it in. Thanks again.
gmtech1
04-03-2013, 10:15 PM
Awesome!! Sometimes a break is all it takes! :smile:
