2002 Olds Sil WB right rear ball joint
Ididnt[BreAK]it
08-31-2012, 08:37 PM
I have a 2002 Olds Siloutte WB AWD everything works great but ... The rear right ball joint popped out of the "lower A Arm" ? can I just replace the ball joint on the lower arm or do they come as a set ? Stupid that there was no grease nipples for this .. it is a moving part. How can I fix this cheap . Thanks and if anyone has a break down on how to take it apart Please add a link.
gmtech1
09-01-2012, 08:05 AM
Rear Axle Lower Control Arm Replacement AWD
Tools Required
Ball Joint/Stud Separator
Removal Procedure
(http://gsi.xw.gm.com/newsi/cellHandler.do?cellId=56131&refDoc=1854970&from=sm#N65562)1. Raise and support the vehicle.
2. Remove the rear wheel.
3. Remove the brake caliper and support the bake caliper. Do not disconnect the bake hose.
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629521.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629521)
4. Use a utility stand in order to support the lower control arm.
5. Disconnect the height sensor link from the lower control arm as necessary.
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629523.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629523)
6. Disconnect the speed sensor harness from the control arm.
7. Disconnect speed sensor harness connector.
8. Remove speed sensor connector mounting bracket.
9. Remove stabilizer shaft link from lower control arm . .
10. Disconnect the shock absorber.
http://gsi.xw.gm.com/image_en_us/gif/000/000/378/378908.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=378908)
11.
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629211.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629211)
12. Remove the lower ball joint nut.
13. Use the utility stand in order to lower the control arm and relieve the coil spring tension.
14. Remove the utility stand.
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629214.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629214)
15. Carefully remove the coil spring (2) .
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629199.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629199)
16. Make a mark on the lower control arm at the cam indicator (1) .
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629235.gif
http://gsi.xw.gm.com/newsi/images/tif.gif (http://gsi.xw.gm.com/newsi/showTif.do?image=629235)
17. Remove the lower control arm to crossmember mounting bolts (1, 5) .
18. Remove the lower control arm.
Install Procedure
1. Install the lower control arm to the crossmember.
http://gsi.xw.gm.com/image_en_us/gif/000/000/629/629235.gif2. Install the bolts (5) and the nuts (4) to the lower control arm.
Tighten
Tighten the nuts to 50 N·m (37 lb ft).
3. Install the cam bolt (1) and the cam washer (2) to the lower control arm.
Important: Align the cam indicator to the mark on the lower control arm.
4. Install the cam nut (3) to the lower control arm.
Tighten
Tighten the cam nut to 125 N·m (92 lb ft).
5. Install the spring jounce bumper to the spring.
6. Index and install the spring insulator to the spring (2).
7. Index and install the spring assembly to the control arms (1).
8. Use the utility stand in order to raise the lower control arm.
9. Install the lower ball joint to the knuckle.
10. Install the lower ball joint nut.
Tighten
Tighten the lower ball joint nut to 60 N·m (44 lb ft).
11. Install the stabilizer shaft link to the lower control arm.
12. Connect the speed sensor harness to the control arm.
13. Install the speed sensor connector mounting bracket.
14. Connect the speed sensor harnesses.
15. Connect the shock absorber to the lower control arm.
16. Connect the height sensor link to the lower control arm as necessary.
17. Install the brake caliper.
18. Install the rear wheel.
19. Lower the vehicle.
After the arm is out, press out and install the new ball joint.
Ididnt[BreAK]it
09-16-2012, 09:29 PM
Thanks you Very much .. I couldn't believe how easy it was to do this with a floor jack and a jack stand,yes i took every safety steps. blocks to stop rolling (slight hill) tire under the frame just incase ... took me 45mins in and out .. lol (I bought the whole lower arm with ball joint $200.00 new better than $600 from the Dealer)
gmtech1
09-17-2012, 07:53 AM
it;7001127']Thanks you Very much .. I couldn't believe how easy it was to do this with a floor jack and a jack stand,yes i took every safety steps. blocks to stop rolling (slight hill) tire under the frame just incase ... took me 45mins in and out .. lol (I bought the whole lower arm with ball joint $200.00 new better than $600 from the Dealer)
Glad to hear it went well!
Don't forget to have the alignment checked!
